TwinTurbo.NET: Nissan 300ZX forum - To correct negative reading on MM reverse probes>>
Subject To correct negative reading on MM reverse probes>>
Posted by ZUL8TR on June 15, 2012 at 7:18 AM
  This message has been viewed 146 times.
In Reply To Re: Here is a link on electrolysis. They note that 0.15v will>> posted by MaxxAction on June 14, 2012 at 01:18 PM
Message for positive volts. Either way you still have the volts indicated on the MM. So look for electric leaks as noted in the link.
As far as the pressure it should still hold above 14 psi. You have a coolant leak but apparently a small one.
ZUL8TR in Orlando,FL
